Unable to Read some Parameters from a Foundation Fieldbus Device
Hi
Im implementing a control system with Foundation Fieldbus to control a Valve positioner. Im trying to read various parameters from the device which is simulated.
Its found that some parameters are not getting read and i have found that those with datatype "Record" is having difficulty and its throwing an error
For Eg: Parameter FINAL_VALUE_RATE_DN is set to 44% and i can successfully read that value
Attached is the image
But the value FINAL_VALUE set to 33% is not being read and an error  is thrown with error NO: Error -2147135731 occurred at FF Read Block Object By Name.vi:3670002
Attached images of NI FBUS CONFIGURATOR for reference
Has anyone been in the same situation?
(1,193 Views)
Hello Altris,
I'm also experiencing a similar issue.
In case if you solve the issue could you please share it here?
__________________________________________
The best way to thank, is to give KUDOS
(1,148 Views)
