02-13-2009 07:22 AM
02-13-2009 07:47 AM
02-13-2009 09:24 AM
02-14-2009 02:19 AM
Hello Flapke,
there are DAQ boards available with a high sample rate on the analoge output (such as the NI 6251). But when we are speaking about sound generation and acquisition you may want to have a look at the dynamic signal analysis hardware. Please note that these cards are simultaneous sampled.
When your academic institute has a academic site license there is a big chance you have also access to the sound & vibration software , when installing this software a lot of examples are added to your example finder.
03-05-2009 08:58 AM
Right, so I got a bit further now. Made some sinus generators that work like a charm, can make pulses and measure them and use a counter to see what the travel time was. Great, except I used a software analog trigger, so the results are completely wrong.
Is there some way to sample the counter at the exact time I send out a pulse from an analog out channel, then sample it again exactly when I receive a signal on one analog in channel and again when I receive a signal on a second channel?
Again, all I have available to me is an PCI-6024E.
03-09-2009 08:17 AM
Hello Flapke,
If I understand you correct you will need to synchronize the analogue input with your analogue output. You can find a great example to do this; multifunction-synch AI-AO.vi (examples => hardware input and ouput => synchronization => Multi-Function). The example is to synchronize the analogue output with the analogue input. You need to do this the other way around.
There is also a excellent tutorial about the synchronization features from DAQmx. I hope this will help you further,
