Ultrabook-CRIO connection
I have a Vaio Pro, but it does not have an Ethernet connector. Sony provides a wireless solution like this:
SONY VGP-WAR100 for VAIO Duo13
If I connect the cRIO in this device port, can I configue it without problems? Has somebody done this?
I want to know it before I buy it.
Thank you
(2,859 Views)
Accepted by topic author vitrion
Hi vitrion good morning:
You can connect cRIOs to any wireless router and configure them correctly. We haven´t worked with this particular Wireless Router, but based on the specifications on Sony´s internet page it is a regular wireless router. You can use any wireless router to configure your cRIO.
Hope this works.
Have a great day
Juan Arguello Director Support Services @NI
(2,818 Views)
Thank you
(2,812 Views)
Hi. It's me again. I finally bought the WiFi router. I connected the cRIO to the router and tried to connect the Vaio Pro to that network. I doesn't work. No device is detected. What can you suggest me?
(2,753 Views)
Hi vitrion:
-Disable antivirus and Windows Firewall
-Use a Crossover Cable and press the reset button on the cRIO for more than 5 seconds to reset the network configurations. If your cRIO has a dip switch activate the IP Reset switch and reset then return the switch to off.
-Check the Network configuration on the ethernet port. DHCP or try a static adress: 192.168.1.X
Check the getting started guide.
http://www.ni.com/compactrio/setup/#gettingstarted
(2,745 Views)
I'd like to use the Ethernet port, but remember my Vaio has not one. I bought a wireless router which converts the Ethernet into WiFi. I'll try all what you recommend
(2,735 Views)
