USRP x300 | Power level adjustment
Hi, I want to know what is the meaning of "db", e.g 30db, 70db and its effects in usrp. Secondly, how can I change the power level in usrp. I want to try modulation/ demodulation of 64QAM, but I am not getting the correct constellation image after equalization at the receiver side. I am using 1G Eth.
(1,498 Views)
Dear ,
db - is decibel, you can follow this link : https://www.britannica.com/science/decibel and know about it more.
You can also take a look at this forum case : https://forums.ni.com/t5/USRP-Software-Radio/audio-transmission-example-using-USRP/td-p/3079056
I think this two links will help you a lot!
best,
anasei.
(1,447 Views)
In usrp library there is a TX/RX gain which ranges from 0-90, what is this factor reflects to in db?
(1,407 Views)
TX- Transmitting pin
RX - Receiving pin
These two indicate whether your pin is receiving a signal or sending. You should configure them based on your project.
 I suggest you looking at USRP communication protocol's working way. It'll make all clear.
best,
anasei.
(1,373 Views)
