05-01-2019 09:04 AM
Hello community,
I have a connectivity problem over USB connection of USRP-2901 in my desktop computer.
Using NI-USRP configuration utility, ethernet based networking based USRP-2922 devices are connecting, yet USRP-2901 does not appered on the list. Also, I tried another computer (my laptop) to see connection problem USRP-2901 and other devices are appeared.
I have upgrated NI-USRP 18.5 software plug in and problem is not resolved. In my laptop, NI-USRP USB devices are appeared also Windows device manager. On the contrast, NI-USRP USB devices are not appeared in my desktop. Is there any USB driver to solve this issue ?
05-02-2019 03:33 PM
Hi orange_spider,
Just to make sure I understand your issue, your USRP-2901 shows up correctly in the NI-USRP Configuration Utility on your Laptop, but doesn't show up on your Laptop. Is this correct or does it not show up correctly on either system? What is the model of the desktop you are using?
05-03-2019 02:48 AM
Hello Luke,
In my laptop Dell XPS 15 9560 it has no connectivity issue. In my desktop Dell Precision tower 5820 has connectivity problem.
05-06-2019 11:46 AM
Hi orange_spider,
Could you try checking for updates for your USB controller drivers in Windows Device Manager? Also, could you attach a screenshot of your USB controllers in Device Manager?
06-26-2019 09:02 AM
I have already updated my device manager, yet NI-USRP does not appeared. My screenshot is given at the attachment.
06-27-2019 09:45 AM
To me, this definitely seems like a driver problem. I know you upgraded the driver, but when upgrading the installer skips over parts of the installation that have been installed previously. Try to force reinstall the driver to ensure all files are overwritten:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P8U0SAK
Also, have you tried different USB ports on your computer? Can you verify that the ports you are using are USB 2.0 or 3.0?
06-28-2019 08:31 AM
Hello, I re-install whole LabVIEW 2018 components and NI-USRP 19.
I tried to connect different USB 3.0 port on the computer but it is not appeared in USRP configuration utility as usrpconf.PNG
Unfortunately, the problem is still unsolved.
07-01-2019 10:32 AM
Are you sure that your USB ports are using 3.0 standard and not 3.1? I've heard of a similar issue in the past (USRP shows up correctly in Device Manager but not in USRP Config Utility) when using 3.1 ports. Are there any 2.0 ports available on the machine?
07-03-2019 08:29 AM
Hello AirFranz,
I just checked datasheet of the my desktop, whole of my USB ports are USB 3.1.
Yet, there are not any USB 3.0 or USB 2.0 avaliable on this machine.
I need to use these devices, what should I do for this issue ?
07-11-2019 10:35 AM
In general the 2901 is compatible with USB 2.0 and 3.0 but compatibility isn't guaranteed on all chipsets. Intel USB controllers are known to reliably work, but many vendors don't indicate the manufacturer of the USB controller. You may need to dig to find this if they don't see it in the documentation or in device manager.
For 3.1 are you using a USB 3.0 SuperSpeed cable? This could potentially be preventing the computer from recognizing as a USB 3.0 device.
