USB-TC01 and DAQ assistant
Hi
When I plug my USB-TC01, I can use the .exe example in the module but with DAQ Assistant in LabVIEW I don't see it. When I use MAX, I don't see it.
Do you know where is my problem ?
Thanks.
(2,618 Views)
I just saw that I use presently DAQmx 9.0.2. I will try DAQmx 9.1.
(2,607 Views)
What version of DAQmx are you using. Support for the TC-01 was added in version 9.1. If the TC-01 is not listed in the readme of whatever version of DAQmx that you are using, you will have to upgrade.
(2,605 Views)
I am sorry to have to add onto a thread that has nothing to do with my question.  I have been searching and searching on how to start a new question (but have failed giving myself ~1/2 hr looking).  So once again ... sorry to the poster and people following this thread.
Now ... my question is ... why will my PC not boot when the USB-TC01 is plugged in??  I have adjusted everything in BIOS to make sure I am not trying to boot from USB nor CD/DVD drives.  Other than that the device works fine once the PC boots.  I tried using a self powered USB.  I am using XP, Pentium D, 3.2GHz, w/ 2BG RAM.  Any help?  I will also continue searching on how to post new messages.
Thanks.
(2,352 Views)
Found the 'new message' ability.  Please ignore the message above.
Thanks again.  I will continue the correct way ...
(2,347 Views)
Hi Yanl14,
If you're going to upgrade DAQmx you might as well upgrade to 9.2.3
Sean Ferguson
Application Engineering Specialist | RF and Reconfigurable Test
(2,317 Views)
