04-15-2009 06:56 PM
I forgot to add that when i said
"Because I am only testing the mouse, I only want to update the correct "USB Human Interface Device" that corresponds to the correct interface. You can easily find that by opening up the properties of "USB Human Interface Device" going to the "Details tab" and looking at the "Device instance Id" information. The information looks like the following "USB\VID_046D&PID_C521&MI_01\6&21C372B&0&0001""
in my previous post. That was in the Device Manager.
04-16-2009 03:33 AM
Thanks for that,
Simple question: Both interfaces have the same VID and PID, right? How do you open a reference to one interface and not the other when using VISA?
Shane.
04-16-2009 11:51 AM
04-16-2009 11:54 AM
Thanks for the info.
So only one interface on the device is updated with the NI-VISA driver?
That I never tried. I always tried updating the root device, which never worked.
Thanks for the tips.
Shane.
08-11-2010 04:38 AM
hi
i want to use computer's optical mouse as a distanced logging device that is i record the mouse position as the mouse moves along a path then I make a relation between the mouse couser position in pixel with length moved by body of the mouse in mm.
Every thing is OK when I use the mouse in short ranges ( 30- 40 mm) and the crusor is in the range of the monitor but when I wana move it in about 1 meter or more which is out of the range of the monitor screen problem began
at the top of the monitor the position is fixed and it do not change anymore. For recording pixels greater than the vertical limit of the monitor I try to set the mouse position to a fix number to get the changes of the mouse position by set_crusor_pos.vi .
but it is not effective.
So I want to save the absolute changes of the mouse position even out of the range of the monitor e.i. if the mouse crouser is at the top of the monitor and if i move it upper I should record a movement in the up side direction.
I want to use my optical mouse a ruler to measure lengths in the range of 1-2 meter.
Many thanks
08-12-2010 01:18 PM
Thisisit,
Did you have a question, or was this a response to a previous post?
01-10-2017 04:50 AM
In windows 10 working on an ACER XC-704 with dedicated keyboard and mouse, the scroll button sticks as do both keys. I have to manaully scroll Last evening I installed IOT for my Rasberry device and the resultant desktop did not show a mouse so the neworking from Win 10 gave the saME PROBLEM THIS TIME WITH A USB COMBINED KEYBOARD AND MOUSE.Sorry about the caps it happens when I touchtype the a.
01-11-2017 10:07 AM
puddle247,
If you have a question regarding National Instruments hardware or software, please make a new forum post as we prefer to keep the scope of each post to one question.
Thank you
