USB-7855R DIO outputs different waveform from the inputted waveform
Hello.
I am using usb-7855r.
I am outputing the exact waveform that I inputted in usb-7855r. however i m not getting the same waveform. The frequency is the same but the voltage level is different. I am suspecting the logic level of the device.
From the user manual or specification of the device, it seems that I can change the logic family but I don't know how.
https://www.ni.com/docs/en-US/bundle/usb-7855-specs/page/specs.html
Does anyone know how to change logic level for this device?
(3,768 Views)
I've never used that card before - but in your project, if you right click on the device or IO item and select properties - is there a panel in there that allows you to configure the logic family?
(blog)
(3,755 Views)
Accepted by topic author dragon1
Hey buddy,
You  want to right click on FPGA Target and click on Change I/O Configuration...
Then you can set the logic levels.
More details in the Help, and in this Tutorial:
Configure R Series I/O Dialog Box - NI-RIO 14.0 Software Help
http://zone.ni.com/reference/en-XX/help/373197D-01/target2devicehelp/configio_dialog/
NI R Series for USB Getting Started Part 2: Advanced
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x5ISCAY&l=en-US
(3,748 Views)
foxhound73 thank you!
I can select different logic levels!
(3,731 Views)
(3,730 Views)
