01-08-2007 10:49 AM
Hi All
I seem to have some brain fade today. I need to use the USB-6009 to with a J type thermocouple. When I hook it up the temperature is not correct and widely varies. I am getting reading from 0 to 60 C at room temperature. I need to incorporate this into another circuit for testing. I assume that I am overlooking the simple and obvious. I have tried using a DAQ Assistant and a DAQmx. Any help will be appreciated.
Gerald
01-09-2007 02:14 PM
01-17-2007 01:19 PM
Hello Gerald,
You don't have a brain fade! I recently got in a few usb-6009's and am seeing a similar response when trying to measure temperature with thermocouples.
I don't believe this is noise as much as resolution on the usb-6009. At this point I have added resistors to bring down noise but am seeing the same "waver" that you describe (although not quite as extreme). I am looking into building a signal amplifier or alternatively purchasing a TAC80 thermocouple-to-analog converter for use with the usb-6009.
Have you had any progress with your issue?
Adzel
