04-09-2008 08:30 AM
I have the same problem. I'm using an IBM T43 Laptop with WinXP, and have used 2 different USB hubs to connect a Chroma 61602 power source and Softlog gang programmer, among other things. I found when I leave the laptop idle for an hour or more, I lost comm with the Chroma, & couldn't re-establish w/o rebooting (I didn't try unplugging & replugging the USB). This was very repeatable. The Chroma is driven from the laptop to the hub to an Agilent 82357A USB to GPIB converter, although I had the same problem when driving it through a USB to serial hub, and a serial cable to the Chroma. I extended my laptop System Standby from 1 to 4 hours and had a complete system update done, and the problem persists. I've called upon Chroma to deal with the problem. Now, not using the Chroma, I have a similar problem with the Softlog device, as overnight (idle) comm was lost. The com port (11) showed ok in my device manager, but didn't show at all in MAX. Restarting the laptop re-established comm. HOWEVER during the restart, I got a blue screen with this message "Runtime Error!" Program:....gram Files\National Instruments\Shared\Tagger\tagsrv.exe This application has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information." The laptop hung up after this message and didn't finish the restart, so I had to manually shut it down & restart. Is this a clue? I now have the Softlog USB cable plugged into the laptop by itself w/o the hub. By the way, the Softlog has its own power supply.
04-10-2008 03:47 PM
Joe Friedchicken
NI Configuration Based Software Get with your fellow OS users
[ Linux ] [ macOS ]Principal Software Engineer :: Configuration Based Software
Senior Software Engineer :: Multifunction Instruments Applications Group (until May 2018)
Software Engineer :: Measurements RLP Group (until Mar 2014)
Applications Engineer :: High Speed Product Group (until Sep 2008)
