USB 6000 digital pin state
I am searching for a way to set digital pin on my USB 6000 to the low state when program stops. By default it laves the last state after stoping, but I have to make sure that in any case when the digital output is not controlled (program is stopped, USB disconnected -> but there the pins are low of course), all digital outputs are OFF. Is there a way to do that, advise please.
(3,804 Views)
Hi Helsinki,
You have a requirement and you know the standard behaviour of your device.
In conclusion the logical way would be to set the DO to LOW just BEFORE you stop your VI, don't you think?
(3,789 Views)
Hey,
thanks for answering.
Yes, it is logical, and you solution is quite obvious. But what is the correct way to "DO to LOW just BEFORE you stop" you propose?
(3,683 Views)
Hi Helsinki,
set the DO to LOW/FALSE before you stop your VI.
The "before" is handled (as usual) by DATAFLOW…
(3,673 Views)
