URGENT HELP NEEDED - Is it possible to create an I-V Characteristic Chart (Photovoltaic) using version 8.2
We are students trying to replicate the output of a photovoltaic cell. We have developed our LabView software to read
both current and voltage across a load but we are not sure how to chart both these real time values. We have found a
NI link  http://zone.ni.com/devzone/cda/tut/p/id/7230  which would be perfect but we only have access to LabView version 8.2.
Any help on trying to achieve similar charts using 8.2 would exetremely appreciated.
(2,880 Views)
You can use the xy graph from the express palette.
It will also place the "built XY graph" express VI that will act as a history buffer if you configure it not to clear data on each call (double-click to change).
See how far you get. Good luck!
(2,867 Views)
Thanks Heaps.....
We have another question..... We have a integer value(dial position) that we want to use in another VI... could you explain how this is possibleplease
(2,861 Views)
Sorry, you should be a bit more specific. What do you mean by "use"? Can you give an example?
  • If you want to call the subVI with the dial position as a parameter, just make a connector for it.
  • If you want to read the dial position from within the subVI, make a connector for a reference to the control and read the value in the subVI via a value property.
(2,856 Views)
Thanks again for the quick reply. We have just posted a more thorough explaination in another post if you could have a look at that one. The VI's are attached.
(2,851 Views)
