02-12-2015 04:22 AM
I've modded my UI to switch from a Table to a Multicolumn 'system'
widget in order to gain some other features and methods :
Yet there is a problem...
I wantedto show a symbol in the columns' header to display the sort
order selected. I wrote a little algo that works quite well and expected
to display an arrow in the header :
I found this but it doesn't help like I expected :
https://lavag.org/topic/7002-multiple-glyphs-columns/page-2
Any info about how to do this ?
David Koch
02-12-2015 07:46 AM - edited 02-12-2015 07:47 AM
02-12-2015 09:00 AM - edited 02-12-2015 09:04 AM
@GerdW : OK, another limitation... I modified my algo this way :
Hence I just add '<' or '>' after the column's name to indicate the sorting order.
Widget : graphic command of a value (tab, edit, button, radio, ...)
David Koch
02-12-2015 09:02 AM
02-12-2015 09:10 AM
