07-27-2011 01:14 AM
Is there an exsit software tool kit can help me decode the UART or RS232 raw data that is sampled for IC pin?
07-29-2011 01:56 PM
MoonSailer,
I would like to gather a bit more information regarding your questions. Could you tell me a little bit more about your application and set-up? Specifically, what National Instruments products are you using and what do you mean by decoding the data? Also, which pin on the RS232 port are you referring to as the IC pin? If you could post any relevant data, it would be most helpful in finding a resolution. Thanks and have a great day!
Trey Chastain
Applications Engineer
http://www.ni.com/support
