Typedefs: Cluster Order with SubPanels Confusion
LV 2010
I'm new at using subpanels, but here's a situation where they solve my problem (since LV refuses to allow a TAB control within a cluster - arrgh).
I have a TypeDef.  It's a cluster with indicators and graphs, describing a page to be printed.
One section of that is an instance of another TypeDef. (call it "X")
Because this section changes, according to what kind of file I'm dealing with, I want to display one of about five sets of info here.
A tab control would do it, but I can't have one within a cluster.
According to the HELP about SubPanels:
you cannot create an array of subpanel controls, and you cannot create a type definition of a subpanel control. You can place a subpanel control in a cluster to group the subpanel control with other controls, but the cluster cannot contain only a subpanel control or controls.
--- So, I put a STRING and a STRING and a SUBPANEL in the X TypeDef.  I put an instance of X on a new front panel.
According to the HELP:
LabVIEW creates an Invoke Node on the block diagram with the Insert VI method selected.
Well, it doesn't do that if it's a TypeDef. Placing an instance of "X" on a panel doesn't do anything special.
So I get the CONTROLS[ ] property of the instance, select out item 2 (0, 1, 2), typecast it to a SubPanel reference, and then I can use the INSERT VI and it works.
But I want to have the subpanel be item #0, so that I can find it in multiple situations: In one case, I might have two strings and a subpanel, in another I might have three strings and a subpanel. If I adopted the convention that the subpanel was 0, then I could extract item 0 in either case and it would work.
But I can't do that. If I try to REORDER CONTROLS in CLUSTER for the TypeDef of X, the subpanel doesn't have a number. The strings are #0 and #1 - there is no #2.
So, is it a control, or isn't it?  If it is, why can't I re-order it?  If it isn't, why does it appear in the CONTROLS[ ] property of its parent?
Is it always going to be LAST in the CONTROLS[ ] array?  What if there are two subpanels in a cluster? Which one is more lastest?
What are the rules here?
If I make the TypeDef NON-STRICT, I can create a direct property node on the panel.  But I think that means I have to make the whole chain non-strict (A PAGE contains a BASIC PAGE + ADDITIONS, the ADDITIONS contains several SECTIONS, the SECTIONS contains X), and I don't want to do that.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 1 of 18
(3,471 Views)
A test shows that if "X" has a subpanel in it (subpanel A), and then I add subpanel B, then subpanel B is item 2 in the CONTROLS[ ] array, and subpanel A is item 3.
In other words, adding a subpanel puts it IN FRONT OF any other subpanels already there.
Steve Bird
Culverson.com
LinkedIn
Message 2 of 18
(3,466 Views)
A couple of possible solutions, neither of which I have tried, as I am in the middle of an upgrade...
  1. You can reorder a cluster by the order you put things into it.  Have you tried dragging everything out, dragging the subpanel in, then dragging everything else back in?
  2. You could use an X-Control instead of a strict typedef.  I know it is a lot more heavyweight, but may serve your needs better.
Good luck.  If neither of these work, let us know and I can make some inquiries.
Message 3 of 18
(3,460 Views)
Yes. Start with an empty cluster.  Place a subpanel in it, then string A, then string B.  String A is item #0, String B is item #1, and in the CONTROLS[ ] array, the subpanel is item #2.
Steve Bird
Culverson.com
LinkedIn
Message 4 of 18
(3,452 Views)
Looks like I made a mistake somewhere though.  You CAN create an INVOKE node for the subpanel, even though it's in a STRICT typedef (I tried earlier and couldn't, but perhaps I gorched something).
So maybe that's the answer for me.  It's not working yet, but I just now tried the first time.
Steve Bird
Culverson.com
LinkedIn
Message 5 of 18
(3,451 Views)
It does work, I was looking in the wrong place.
You CAN create an INVOKE NODE to a subpanel, even if it's within a strict typedef within a strict typedef, within a strict typedef.
The other questions still stand as points of confusion, but not as obstacles now.
Steve Bird
Culverson.com
LinkedIn
Message 6 of 18
(3,448 Views)
Hmm.  I can make an INVOKE NODE to the panel on my main page, even if the subpanel is in a typedef inside a typedef, etc.
However, if I go and EDIT that typedef, even moving the subpanel a single pixel, the INVOKE NODE just disappears, leaving a broken wire.
Steve Bird
Culverson.com
LinkedIn
Message 7 of 18
(3,440 Views)
Hey Steve,
Can you attach the vi, and clarify what the remaining problem is?
A. Zaatari
Message 8 of 18
(3,420 Views)
I've made a small test thing which showed up ANOTHER issue.
Open the top-level VI in the attached LLB.
Notice descriptions on diagram.
#1.  Run it out of the box, as it is.  Why are the displays BLANK?  I am clearly executing the VI BEFORE it's inserted into the SubPanel. If you flip the switch, the displays react appropriately, so it's not caching anything.
#2:  Make a change to the typedef and POOF! the INVOKE NODE disappears.
#3 is a request for clarification of the rules.  If it's not a control, why is it in the CONTROLS array?  If it IS a control, why can't I REORDER it in the Typedef?
Steve Bird
Culverson.com
LinkedIn
Message 9 of 18
(3,410 Views)
Hey Steve,
I was able to recreate the issue, and will get back to you on why this is going on.
A. Zaatari
Message 10 of 18
(3,394 Views)
