Two data types transferred via DMA FIFO: Hexadecimal and FXP - incorrect decoding at Host side.
Thank You Raphael,
Now test phase ...
Best regards
Tomasz
Message 11 of 12
(831 Views)
Hello Raphschru,
I'm conducting some test with this code - and I reached soem open questions:
  • In main Loop is timer wait - setuped for 20 ms - why that delay?
  • I setuped Timeout of both Invoke Methods for -1. I don't find good explanation how to calculate this timeout but I wanted to not have delay/ I'm not sure if this is correct approach.
  • I think that a good practice ( in code optimisation point of view)  should be creating producer - consumer pattern with QUEUE and separate decoding, saving and visualizing tasks in consumer loop.  My firsts attempts with QUEUE gave me worse results than reached with actual code - I see some gaps in data - probably because incorrect QUEUE configuration
  • How to configure the queue in this case?
  • Attached are Copy_4 - without QUEUE and Copy_5 - with QUEUE.
With QUEUE I see some gaps in Time records - they should be perfectly straight , linear increasing. There is missing periodically about ~300 ms.
How to prevent this "breach"?
Best regards
Tom
Message 12 of 12
(800 Views)
