Two FPGA bitfiles running parallel on sb-rio 9607
I am developing a small scale microgrid system which I have to run two bitfiles run on the FPGA target simultaneously. I tried putting two separate FPGA VI references on the same RT application, but it seems like only one of the two references is running. Could anyone help me with this issue? or Is it even possible to run multiple FPGA bitfiles simultaneously?
(2,199 Views)
Accepted by topic author incasekim
Hi Kim,
one FPGA, one bitfile. Simple rule…
You need to combine both FPGA-VIs into one and compile a bigger bitfile!
(2,191 Views)
