Turn off "Run Continuous" in VI
Highlighted
I have a complex VI that needs to be run multiple times to iterate a solution. Right now, I hit the "Run Continuous" button and wait until it converges to a solution. I would like to be able to turn off the Run Continuous mode once I detect convergence within the program. Is this possible? I was looking at a "This VI" ref to an invoke node, but do not see an option here.
I don't want to trigger a "Stop" as I want the program to finish it's current iteration normally.
Yes, I could make a calling program, but there are too many variables etc. that would need to be wired into the connector pane.
Thanks for any suggestions.
(277 Views)
Highlighted
Accepted by topic author waynep
Is there a reason to not enclose the whole vi in a while loop and use a stop button to stop the loop? The loop will finish its current iteration when the stop button is triggered.
(266 Views)
Highlighted
Well, let's put it this way:
There is every reason to stop using the "Run Continuously" button as your solution, and every reason to use a loop, instead.  The "Run Continuously" button is only a debugging tool.  If used on anything other than a VI with the simplest architecture, it could lead to some unexpected results.
Bill
CLD
(Mid-Level minion.)
(260 Views)
Highlighted
Yes, that is possible with my "converged" indicator stopping the loop. I will probably do that if there is no way to just turn off the Run Continuous mode from within the program.
The reason I am not doing that is I have a mode of operation that only needs to run once, but I suppose I could just stop the while loop at 1 run in that event.
But, I have become curious now whether it is possible to do what I asked. Perhaps, I may learn something following that path...
Thanks for the suggestion.
(256 Views)
Highlighted
If you need to run continuously until some condition is met you should use a while loop and exit on that condition. You should not be using the "Run Continuously" button.
(243 Views)
Highlighted
Thanks for knocking that dumb idea out of my head -- that is what I needed. I have already implemented the while loop and it (of course) works fine. I am not sure why I didn't do this initially as I have done the same thing many times in the past. Sometimes your thinking can get stuck in a certain direction and it takes some prodding to reset.
Another obvious reason to make the program self-contained is if I wanted to make an executable.
(227 Views)
