12-29-2013 09:13 PM
Hello!
I am trying to do a vi that uses the .NET Constructor, and System(2.0.0.0), and DeliveryNotificationOptions.OnSuccess, but I don't know how to use it.
What I am trying to accomplish is to have a vi that handles some special emails that the company needs to send and then administrate the delivery notification responses, if it has reached the destination mailbox, and if it was read. I already have a vi client made for receiving the emails, but I want to configure the emails sent to have the Delivery Status Notification, and if it is possible the read notification.
Gilberto Garza
12-30-2013 10:32 AM
Not sure if this is what you meant, but the DeliveryNotificationOptions is a bitwise flag enumeration: You can get the value you need for a delivery receipt by using a static property node on the DeliveryNotificationOptions class. Read receipts are a bit different. For this, you apparently have to add a custom header to the email named "Disposition-Notification-To" where the value is the address where the reciept should be sent. Of course the functionality relies on the recievers server supporting the functionality. If you need more info, I would suggest searching MSDN since the question is more about the use of a Microsoft .Net assembly.
