10-16-2017 02:07 AM
I have created a webservice project and tested it under development system 2015.
Now I want to publish it on a PC system without Labview development system is installed.
I have created an installer only with the webservice without an executable.
I run the installer on the other PC system without any problems but the webserver is not reachable under http://localhost:3582
I have checked if the system webserver service and the application webserver service are running. They do.
I have checked if another application uses port 3582 with NETSTAT. The port is only used by NI System webserver. So it should be ok.
Does anyone have an idea?
Solved! Go to Solution.
10-18-2017 01:42 AM
I have solved the problem.
When you create an installer you have to select "NI web configuration and monitoring" manually.
It is needed to access the NI system web server by a web browser.
