Trying to merge large files
I am trying to merge several large files into a single file. Each of the files contains several hundred Megabytes of Data in several columns of Tap deliminated txt files.
If I just try to open them, merge them in a concatenating for loop and writing a new file I constantly get the error not enough memory.
What is an easy way to merge several files into one, while avoiding the memory overload issue? Each file contains 4 columns with millions of rows of data, the final file should have the same amount of rows as previously but each column added at the end.
Thank you for your help
Message 1 of 11
(4,786 Views)
Adding columns to a text file is difficult to impossible.
If you must use a text file then I suggest(it may not work),
open 1 file convert to binary, close file, open second file convert to binary append to binary array, repeat for third file.
Now you have a binary array of points, convert it to text in chunks, say 100k rows at a time. Append each chunk to the new text file.
mcduff
Message 2 of 11
(4,770 Views)
This task would be better performed in Excel itself.
If you were clever you could:
  1. open several of the files
  2. record or program a macro of you appending a column from one sheet to another
  3. playback that macro for the rest
=== Engineer Ambiguously ===
Message 3 of 11
(4,755 Views)
I would read all of the files 1 line at a time.  You then merge everything into a line and write that line.  Repeat until you have read all of at least one of the files.
Message 4 of 11
(4,754 Views)
Command window (or system exec)
Copy [file 1] [file 2] .. [file n] [destination file]
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 5 of 11
(4,745 Views)
I think copy will append them row by row (add rows, not increase column count).
You may be able to hold all of your file references open and scan blocks from each file, use the Spreadsheet String to array (of strings) and appropriate Transpose operations and build array to go through faster than line by line, but it seems likely you cannot open and read all of any one file and make progress.
GCentral
Message 6 of 11
(4,727 Views)
Accepted by LukasSc
OK, I think you have some ideas for a solution. But having hundreds of megabytes of data stored as text files is not very good. Merging several of them to create a text file of gigabyte-size is worse. What do you need it for? It will be extremely slow to use and extract data from. Consider using tdms for storing that amount of data instead.
Certified LabVIEW Architect
Message 7 of 11
(4,591 Views)
Wow TDMS files seem indeed promising. I might have to rewrite some of my Data Acquisition procedures but it seems worth it. Thank you for pointing that out, I wasn't even aware of the format.
Message 8 of 11
(4,565 Views)
If you're willing to switch to TDMS files, you have the significant advantage of being able to write new columns separately.
That would allow you to parse entire files at a time, and just keep adding new columns (perhaps based on a header row in the existing files?) to the TDMS file.
For TDMS, these would be Channels probably (although you can consider using Groups to group similar measurements, or perhaps to separate by source file, or however you wish).
GCentral
Message 9 of 11
(4,556 Views)
TDMS really is the Koenigsegg and rolls Royce of file formats to use for storing data. It is simple to start using, versatile, reliable like a rock and faster than anything.
Message 10 of 11
(4,532 Views)
