Trying to make 1d to 2d subvi
Hello all.  I am trying to make a subVI that will convert a numerical 1d array into a 2d array.  I want the VI to be able to accept different dimensions for the 2d array and be able to adjust accordingly.  I tried to use the Reshape Array function, but I get an error if the input and output arrays do not have the same dimensions.
I have also used nested For Loops, which seem more successful, except I can't get the columns to update correctly.  I know the reason for this is because I don't know how to increment the inner loop and insert it into the array.  I'm not sure if I should use a local variable for the 2d array and put it inside the inner loop.
I have both versions (Reshape Array and nested For Loops) in this program.  I will use whichever works and get rid of the other one.
I'm trying not to use Build Array since I read that Build Array makes a copy of the array each time it runs.  I may be doing the same thing with what I am doing, but I don't know.
(999 Views)
Accepted by topic author Dhouston
Hi Dhouston,
Because your output array is labelled "2D array", but it is a 3D array - which is shown in the context help when you move the mouse over the broken wire!
Why are those #rows and #columns control set to I8 representation? After correcting the error(s) your VI should look like this:
(995 Views)
Yep, that solves the problem.  Thanks!
(968 Views)
