Trying to add an eds file to Verstand / Labview
New to the LabView / Veristand environment. I am trying to create a project and add the eds file of a linear actuator to LabView. I wonder how to set it up and where to upload the file.
Best,
Scout112
(1,154 Views)
Hi scout,
Are you using Veristand or do you use LabVIEW?
Which version do you use?
Do you use a LabVIEW project? You can "add" all kind of files to LabVIEW projects…
An EDS file typically describes the communcation parameters for a device, I used them with CANopen devices. Do you have any CAN hardware connected? Do you have any CAN drivers installed (in LabVIEW)? (You may replace the words "CAN"/"CANopen" with any communication bus you like to.)
Please describe your setup with much more details!
(1,138 Views)
Hi Gerd,
Thanks for the reply. I am in the early setup phase of the project and is trying things out. I am using cRIO9012 controller +cRIO 9112 chassis with NI 9881 CAN Open Module, to control a CanOpen linear actuator. The actuator is currently not wired to the controller, I am just trying to setup the cRIO and NI9881 module. I am deciding between LabView and VeriStand. Ideally, would go with VeriStand.  This is the software / drivers I have right now (was trying out the online LabView trial, that's why I asked about it).
Would love to hop on a call to learn about this if that could be the best use of your time. Lmk
Best,
Scout
(1,105 Views)
