Trouble with "Write waveforms to file"
Hi folks,
I'm having trouble with "Write waveforms to file." Attached is a very simple vi that gives the error message: "Error 4 occured at open file ... LabVIEW: end of file encountered ... NI-488: invalid argument or arguments to function call."
It gives this message whether I put in a new file name or one that already exists.
The last part is rather puzzling since I'm not doing anything with GPIB.
I found this KnowledgeBase article, but this is not the same case, since it happens the first time I address the file:
http://digital.ni.com/public.nsf/websearch/0576444C8FD4DC0F86256E83007FA540?OpenDocument
This is Windows 7, LV 2013 SP1.
Any advice would be much appreciated!
(4,680 Views)
That error is a little misleading, but basically it means you are not giving the waveform data that it is expecting.
(4,675 Views)
Thanks for your reply!
So... what does it expect? I can grab a waveform constant from the palette, put some values in, wire it up, and get the error. Or I can get a waveform from an instrument, same thing.
(4,668 Views)
Accepted by topic author AllisonAFM
In the examples that ship with LabVIEW there is one that should be useful  Waveform - Write Waveforms to FIle.vi
(4,662 Views)
Ah, found it, thanks. Starting with a functional one and a non-functional one, and working toward the middle, I traced the problem to the Open/Create/Replace. I guess with that in the code, the write function is not actually the first time I address the file-? Anyway, I've got a working bit of code now.
(4,633 Views)
Glad you got it working!
(4,610 Views)
