Trouble with motor control
Good morning!
 I apologize for the late replies, but for the update, I was able to download NI-MAX into the computer and found this:
I really do appreciate the patients and help through this process and cannot thank you enough!
Message 11 of 14
(630 Views)
Thank you so much for this input NIquist! I am changing the code right now to use Enum. By any chance may I see how you ran the code using Enum on a file? If it's too much that's very understandable! I am doing my best to make sure I am understanding and learning the processes for future projects as well. 🙂
Message 12 of 14
(626 Views)
You have no COM ports.  That's why you can't use a serial connection.
If you have a desktop PC, almost all of them should have COM1.  If you're using a laptop, then you need a USB to Serial adapter.
Check your Device Manager too.  You should see the hardware under the Ports (COM & LPT) section:
Until Windows can see it, NI-MAX and LabVIEW won't be able to either.
FYI:
Using Enums in Labview Case Structures - NI
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 13 of 14
(611 Views)
Thank you so much for taking time off your day to answer my questions, I really appreciate all the help given! And yes, it has answered most of my questions 🙂
The only issue now that I have been having is that my code will not stop or it would still have trouble turning counter clockwise and then counterclockwise whenever the user decides to switch the rotation.
Message 14 of 14
(587 Views)
