Trouble mixing DAQmx Events and User Events
you can bundle dynamic event reg refnums into a cluster, and wire that cluster into the event structure.
--- Thanks for that, I hadn't thought of trying that.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 11 of 16
(1,078 Views)
you MUST do the registration BEFORE THE TASK IS STARTED
What version of DAQmx?
Damn Steve! this sounds like a fun one.
Greg doesn't know how to spell "Life"Smiley Wink
"Should be" isn't "Is" -Jay
Message 12 of 16
(1,077 Views)
NIDAQmx 9.7.5 - LV2013 - LVRT 2013
Another problem I found was because I had slipped onto the host PC.  I'm supposed to be running on the PXI (where I have hardware), but I discovered one of these test things was on the host PC.  Duh.
This JING still shows a LV Bug, though: <http://www.screencast.com/t/cNyxANoMH>
That REGISTER node is happy when I wire the cluster to it.   When I wire the other REG. REFNUM to it, though, it changes personality.  You cannot expand it, you cannot shrink it -- it just goes all "tharn".
And then if you hook up the output line, it breaks the input connection?  why is that?
Steve Bird
Culverson.com
LinkedIn
Message 13 of 16
(1,072 Views)
SUCCESS!
I originally had the DAQmx REGISTER function after the task config and before the START.  But in all the fumbling around, I had moved it to AFTER the start.
LESSONS LEARNED:
1... Cannot register events on a task that has been started.
2... Cannot combine a DAQmx Registration with a user registeration. (Still don't know why).
3... Pay attention to where the dang thing is running!
Thanks, everybody!
Steve Bird
Culverson.com
LinkedIn
Message 14 of 16
(1,071 Views)
Again, haven't watched the jings because I'm lazy Smiley Tongue, but my guess is it's somehow due to the strict typing of the wires. It is because of this strict typing that I always use bundle, with each dynamic event refnum representing only a single event, not multiple events with an expanded registration node, serialized registration nodes with the dynamic event reg refnum wired through them all, etc. Only PITA is that unregister doesn't accept the cluster even though dynamic event terminals do Smiley Mad.
Message 15 of 16
(1,051 Views)
Another trick, you can use coerce to type to give more meaningful names to your event wires so when you register them they aren't just called "event registration refnum.<event name>"
Message 16 of 16
(1,046 Views)
