Triggering in Labview using Analog Input Signal
Highlighted
Hi NI community,
I am trying to acquire an Analog Input signal using LabVIEW (2010). I am using input analog signal (like sine wave) as a triggering source. Also I want to record the same wave/pulse.
How can I do this operation?
I am using NI-PXIe-6124 card.
(469 Views)
Highlighted
What is the problem? The DAQ? The triggering? The logging?
What do you have and where did you fail?
(444 Views)
Highlighted
Thanks for your response.
I am using the start trigger option. When I use rising edge and set trigger level, the data previous to trigger level is not recording and the intial pulse is not capturing completely.
so I want to record some data prior to trigger so that I can get the full pulse.
(441 Views)
Highlighted
I'm not sure if the hardware is capable of doing that.
Here's the scheme I used (with different HW).
1) Start capturing data. Store it in a memory buffer. Data beyond the pre-trigger time can be removed from memory. Usually, the buffer is a 'circular buffer' type.
2) Analyze the data (in a parallel loop of some kind), to see if there's a trigger.
3) If so, store the buffered data, and wait for the post trigger data to come in (while storing it as it comes in).
(431 Views)
