02-23-2011 05:16 PM
Hi all,
I'm trying to take a speed measurement off of a shaft using a hall effect sensor and a 9402 module in a 4 module cDAQ 9174 chassis. I've used the low frequency measurement example using DAQmx but if the shaft isn't spinning I get a timeout error.
Two questions, is there a way to use the Express VI's to accomplish this and how do I create a trigger to start the measurement?
-Ian
02-23-2011 09:22 PM
Why not clear the timeout and report 0 RPM. The timeout is 0 rmp but you dont want to wait forever and block program flow.
02-24-2011 08:12 AM
Yes, that is exactly what I'd like to do but how can it be achieved without causing the program to hang?
-Ian
02-24-2011 06:59 PM
In the read, specify a timeout. the read will return and not block.
