08-24-2012 07:32 AM
@no87 wrote:
I cannot create a front panel control in the same VI, but I can create a front panel control in another VI (the VI I am calling "scripted VI"), which is exactly what I am doing. But therein also lies the problem, because I cannot access an event on the front panel of the scripted VI from the calling VI, which I tried using a property node with mouse modifiers.button down. Could you please take a look at the VI I posted?
Have you tried to register a dynamic event against the control in question?
I do this often and it works fine for me.
Ben
08-24-2012 07:40 AM
Ben, that is a much better suggestion than the one I gave. It keeps all the code in the creating VI and neatly solves the communication issue between the two VIs.
08-24-2012 07:44 AM
Thank you DF!
That means a lot coming form you.
Ben
