08-23-2012 09:38 AM
I have a VI that is creating a scripted VI with a couple of pictures in it, opens the front panel and executes the scripted VI. Now I want to trigger an event by clicking on one of the pictures. I thought I might be able to do that using the mouse modifiers property node, but it looks like the VI does not react on events on the scripted VI's front panel.
If anyone had any idea on how to proceed I would really appreciate it.
08-23-2012 09:50 AM
duplicate post, answered here : http://forums.ni.com/t5/LabVIEW/Triggering-an-event-on-a-picture-created-with-LV-Scripting/m-p/21335...
Epictetus
08-23-2012 09:50 AM
If you want an event triggered by clicking on a picture in the scripted VI, you will need to script an event structure into the VI to capture the mouse event and send that event to wherever you wish to process it. This is complicated by the fact that the event structure is not very scripting friendly. You have a couple of choices:
Item 1 is probably easier. You can send the event to your original VI using user events, queue, etc.
08-23-2012 10:35 AM
This should contain all the interesting parts...
08-23-2012 10:42 AM
I don't think that your suggestion is viable, because the picture in the scripted VI is only being created while executing the VI, therefore I cannot create a template containing it, can I? And because all I have of the picture is a reference, I cannot use an event structure either. Please correct me if I'm wrong...
- Create a template which contains your picture, the event structure and prepopulated event case. Move this from your template to your scripted VI.
- Create a template which contains an event structure and user event for the picture mouse event. Move as before.
08-23-2012 10:48 AM
You cannot create a front panel control while a VI is executing. This would require compiling the VI while it is executing. Normally, pictures are created in a picture control, which has a rich set of events available which can be dynamcially tailored to the contents of the picture (e.g. filter based on location). All of this happens in the event structure in prewritten code. One could also drop a picture as a decoration, and events on it would then be handled with panel or pane events filtered to the correct area. Finally, one could use the picture as a background and again use panel or pane events filtered for area.
08-23-2012 11:06 AM
I cannot create a front panel control in the same VI, but I can create a front panel control in another VI (the VI I am calling "scripted VI"), which is exactly what I am doing. But therein also lies the problem, because I cannot access an event on the front panel of the scripted VI from the calling VI, which I tried using a property node with mouse modifiers.button down. Could you please take a look at the VI I posted?
08-23-2012 11:16 AM
I did use the template technique mentioned by DFGray, example posted here : http://lavag.org/topic/13499-utility-that-creates-vis-to-readwrite-a-section-cluster-fromto-ini-file...
I think you could use it too.
Hope this helps
ps : can't open your VI now, I'm installing LV 2012...
Epictetus
08-23-2012 12:06 PM
Right, just took a look at you VI, indeed, I beleive your best option is to create a template VI with a picture control on the FP and a event structure on the BD, in that event structure create and event on the picture control (either value change or mouse down event) save that VI and in your scripter VI instead of creating a new vi from scratch you can create a copy of the other vi, run it and then fire the event on the picture control.
The link I gave above uses a similar technique, hope it makes sense to you.
As DFGray said you can't create and event structure and add events to it with scripting (well you can create an event structrue and create frames but then you can't edit them to define what event you want them to catch, it would be cool to be able to do that but I doubt it's a priority for NI to extend scripting that way.
Enjoy!
Epictetus
08-24-2012 07:25 AM
I've just posted an idea for a more scripting friendly event structure : Vote here!
Epictetus
