Trigger labview analog output by phantom high speed camera
I am able to produce an analog output by using LabView. Now, I need to trigger the analog output using a high-speed Phantom camera (Image based trigger). Can anyone please help me in this regard?
Thank you
Pieterson
(2,775 Views)
Without knowing more about the hardware platform you are using, I can tell you that there are resources available on the NI website to learn about machine vision applications.
Have you confirmed that your hardware is compatible with NI drivers
(2,751 Views)
Thank you GBN.
I am using NI-9263 module on cDAQ 9174.The phantom camera I am using is V7.0
(2,717 Views)
