Tree control, Disable but still use Scrollbar?
Hi Experts
I'm using a Tree control and the user can select one or more Items (rows)
Sometimes i need to lock the control so that the user cant change the selected items. I use a Property Node to disable the control.
However the Disable also disable the Scrollbars.  Smiley Mad
I want the user to be able to vertically scroll through the Tree, without the possibility to change the value. (selected items)
How to do?
Best regards
Per
Message 1 of 11
(4,221 Views)
Ideas:
- Use separate scroll bars
- Don't disable but instead discard events that you see as "change".If it's a value-change, then maybe you could jut set the value back to what it was.
Certified LabVIEW Architect
Message 2 of 11
(4,192 Views)
How about this? Run the attached VI. Two rows are selected, but when you select another row, the selection is set to what it was.
Message 3 of 11
(4,187 Views)
Accepted by topic author PMN1966
If the tree is always disabled, it should be fairly easy to do something like the attached.
Basically, the tree has a method that converts a mouse click to a row/column and will also tell if the mouse click is within the content rectangle of the tree.  If it's not, that means the mouse click occurred on the border of the tree or inside the scrollbar.  Either way, enable the tree for scrolling until the mouse goes back up.
If the tree is sometimes enabled and sometimes disabled as you say, you'll need to store the current disabled status and restore it on mouse up.  If it's already enabled, you don't want to disable it on mouse up.  I'll leave that for you to figure out.
aputman
Message 4 of 11
(4,157 Views)
You could also just use the Discard? terinal in that Mouse Down?  event when you decided that you do not want the user to change anything. Or use the similar Edit Cell?  filter event instead.
Rolf Kalbermatter  My Blog
Message 5 of 11
(4,155 Views)
I don’t think so. If you discard the mouse down, you won’t be able to use the scroll bar.
aputman
Message 6 of 11
(4,152 Views)
Even if you only discard it when it is in the visible colums?
Message 7 of 11
(4,147 Views)
Thanks Aputman!
Exactly what i asked for. 🙂 There are some cool functions that can be implemented with that method!
Another question. Is there a way to do the same with Indent/outdent? (still without allowing to change the value(s))
In some situation i want the user to browse through the tree without changing the selection. (access to Scroll, Indent/Outdent.)
In other cases it should be possible to have full access.
Best regards
Per
Message 8 of 11
(4,133 Views)
I think Rolf's suggestion is better - it doesn't require toggling properties.
Message 9 of 11
(4,128 Views)
Hi Pauldavey
Agree. !
But the main solution was to use the "Mouse in bounds" methods as aputman surgested.
Br Per
Message 10 of 11
(4,111 Views)
