Transparent NXG or JKI Flat buttons
Hello, I want to have some buttons with a transparent background regardless whether the buttons is clicked or if the mouse is hovered.
However, when I use a button from the NXG or new JKI Flat package, changing a color from the properties menu causes the mouse hover color to become black regardless of which color I chose. If I do it programmatically with a property node I can only change 4 colors (ON, OFF, T>F, F>T) and not the hover color.
How can I change this to also be transparent?
I've attached a sample vi to show the problem.
(282 Views)
Question: why are you using a button with hover states, if you don't want hover states?
(262 Views)
Because I have an icon package (in this case JKI Flat) that doesn't have buttons without a hover state.
(248 Views)
Accepted by topic author Basjong53
So, this property node says colors[4] but it's lying, you can actually shove 6 colors in there and it will work if it is a six state button. I was so confused the first time I tried it, but it really works. The order (if I remember correctly) is false, true, true transitioning to false, false transitioning to true, false mouseover, true mouseover.
(224 Views)
Highlighted
Hah, that does indeed work, really weird that it says colors[4] then. Thanks for the answer!
(115 Views)
