Transfer signal from UDP
Hello. In my project it is necessary to transmit a signal from PXI to the ADC NI5783 to another computer using the UDP protocol. To solve this problem, I used the standard example of simple UDP. But I had a problem with the timing of the signal. How to make the signal synchronization on the second computer?
(1,596 Views)
I don't think you'll be able to.  Network communications aren't deterministic, and certainly not UDP which can't even guarantee the signal will arrive.
(1,567 Views)
UDP is an undeterministic protocol. Wouldnt it be possible to implement the same using TCP?
(1,524 Views)
