02-27-2012 10:33 AM
Hallo all,
I am running a 64 bit version of Labview 2011 and I would like to know is it possible to use transfer functions in this version?
I found only a 32 bit version of Control Design and Simulation Toolkit, is there something else I could use for this?
Thank you,
Vladimir
02-28-2012 10:04 AM
Vladimir,
That is correct. At the moment we do not have Control Design and Simulation Module for 64-bit LabVIEW. However, you can install the 32-bit version of LabVIEW into the 64-bit OS (it will show under Program Files (x86) folder), and then, install and use the LV CD&SIM. The "32-bit" products works normally in 64-bit machines. The only time you would need to use LabVIEW 64-bit is when you deal with large files, which is rarely the case for transfer functions.
Hope this helps.
02-28-2012 10:11 AM
Thanks for your posting in this forum. Unfortunately you cannot use this function in the LabVIEW x64. You can check the link below
http://forums.ni.com/t5/LabVIEW/LabVIEW-64-bit-support-for-modules-and-toolkits/td-p/996044/page/2
But you can try the option below, but I cannot say that it would work.
You can install the LabVIEW x32 and then Control Design & Simulation Module .
Then copy the library of this module somewhere else.
Then you can install the LabVIEW x64 and copy that library in its folder.
Maybe it works.
Hossein
02-28-2012 10:18 AM
Thank you for your suggestions. I will try copying the folder to the 64 bit program folder. If it doesn't work, I will try running the .vi in the 32 bit version. I will let you know if it is possible to migrate the toolkit to the 64 bit version.
Vladimir
02-29-2012 09:05 AM - edited 02-29-2012 09:07 AM
Just FYI, copying won't work. The module is not 100 % G-based source code and the call library node is not compiled to Windows 64.
You are better off just installing the 32-bit version on your machine and it should work file.
02-29-2012 09:17 AM
I tried copying it, but its impossible even to copy all files because they are not in a single folder (and the installer doesn't allow installing the toolkit to other folders except for the Labview 2011 folder). I already started working with the 32 bit version of the program.
Thank you for your help!
Vladimir
