Transfer files from scope to PC via GPIB
HI, how do i transfer the files to my computer? i am using LabVIEW 8.0 and TDS 694C scope. i tried using the Hardcopy start command but it doesnt save it into my C drive. i also tried to use TKTDS Hardcopy.vi from the drives but it also wont work. when i type hardcopy?  it will show this . BMPC;GPI;LAN;HARDC;"fd0:/c:/TEK??   .BMP"
when i type hardcopy:filename? it will come out "fd0:/c:/TEK??   .BMP". instead of saving it to the diskette on the scope i want to be save it in my harddisk. how do i set it to do so?
Message 11 of 17
(2,329 Views)
That command will obviously not work because it is a query. Anytime you append a '?' to the end of a command, you are asking the instrument to provide some data. You are not telling it to save anything?
A careful read of the instrument manual is probably in order.
Message 12 of 17
(2,322 Views)
well those commands is just to show you the status of my problem. how am i able to set it to save to C:\ instead of having to start with fd0:
how do i send my files from scope to PC?
Message 13 of 17
(2,309 Views)
would anyone please help me to convert this VI. from ver 5.1.1 to ver 8.0
Message 14 of 17
(2,302 Views)
Since you have 8.0, I don't know why you just don't open it yourself.
In any case, it really needed some cleanup. I've posted a modified version. As you can see, the correct command for the hardcopy is to direct it to the GPIB port. You then do a read and save it to a file.
Message 15 of 17
(2,289 Views)
HI Dennis, thanks for converting the vi for me. but when i tried to run it showed some errors. how do i solve it?
Message 16 of 17
(2,262 Views)
I can't run it but you don't have a valid path. All that you have is C:\. You need to have a file name.
Message 17 of 17
(2,257 Views)
