02-28-2012 03:35 AM
Hi everybody
i need to create a filter from a transfer function. I get the transfer function from a frequency response of a DUT and then i have to implement it. I try to explain better: i plot the frequency response of my DUT, i make a fit of the response and get a polynomial equation that describe that curve, then i inverse the transfer function plot and and put the new polynomial equation in this form: 1 / (a0 + a1 X + a2 X^2 + ...). Now i think i have to go from X to frequency domain and then i can implement the transfer function to obtain a filter to filtering a waveform.
Is it correct?? Do you have any other idea??
I have the Digital Filter Toolkit and The Control e Simulation Toolkit.
Please let me know if you have an advice
Thank you
02-28-2012 04:55 PM
Well i mean..
is it possible to build a filter that has a magnitude/frequency response which follows the course of a curve (a frequency response) that has a well know formula??
Thank You
03-05-2012 08:03 AM
Hello Nigeltorque,
have you taken a look at the following example?
http://zone.ni.com/devzone/cda/epd/p/id/3249
Does this respond to your question?
