11-20-2018 12:15 PM
Can you post an image of the FPGA VI? It could be that the indicator has been optimized out of the compilation.
11-21-2018 02:33 AM
Hi all,
The clock edit is done before the run start, so yes I could adapt the host manually to meet this change. However, what I wanted to do is to automatically read this value, in order to avoid changing the Host VI manually every time I use a new clock. It is just a metter of develop a more "flexible" software.
What I think it is just like you suggested, so that the clock value it's like an internal variable of the FPGA., but I can't figure it out why it is so..
Cirrusio, for what concern the VI, I can't really post my real code. However, i attached two simplified version of my program that will show to you the problem.
11-21-2018 02:47 AM
Hi ALST,
I guess the "clock edit" is done before you compile the FPGA VI?
When you do so you could change a numeric/enum constant and wire it to an indicator in the FPGA code. This way you could create several bitfiles with the same interface to the RT host…
I guess it is so because that clock reference is used to tell the Xilinx compiler which clock signals to generate and use in the FPGA fabric - it's all internal in the FPGA!
