Tracking Movable Objects – the coordinates of the objects are not correct
Hello
I would like to track movable objects in Labview. I use Shape Detection module for spherical objects tracking. I noticed the following problem. I have two objects. A launched a sequence of 5 frames. At the first frame the XY coordinates of the object 1 are taken from the object 2 and vice versa. The other frames are OK. How to resolve this error?
Thank you
(589 Views)
You mis-wired the fourth (or is it the fifth?) function in the Code You Failed To Post (we only accept VIs or, better, entire Projects, formed by compressing the Folder containing the Project and attaching the Zip file).  I promise not to look at any "pictures of code" you choose to post -- it's a waste of my time and eyesight.
(559 Views)
