I have a top-level VI (I_PI_MSL.vi) which is runnable. It currently references a sub-VI named MSL_DISPLAY.vi. In an earlier revision of the source code base, MSL_DISPLAY.vi was named MS_DISPLAY.vi.
When loading I_PI_MSL.vi into LabVIEW 6.0.2, it stops and prompts for the non-existent MS_DISPLAY.vi--I press cancel to bypass this VI and it goes on, ultimately leaving me with a still runnable I_PI_MSL.vi.
MS_DISPLAY.vi is not referenced anywhere in the I_PI_MSL.vi diagram or front panel (using the search function to check).
However I can hexedit the file and find that name string.
Have tried saving the source-code base back to version 5.x and reconverted it to clean up this item.
Have gone back to the original cod
e-base, copied MS_DISPLAY.vi to MSL_DISPLAY.vi, and then replaced it on the diagram with the same result.
Something is out of kilter with the original I_PI_MSL.vi. Any alternative suggestions for repair?
Can post sources if you have suggestions but need to take a look, but is multimegabytes.
David Fackler
