Toolkits required for programming and FPGA via labview.
Can any one let me know what are the required NI toolkits for programming an FPGA (Kintex 7 and the FPGA in NI USRP 2944R) via Labview along with the product details?
(2,179 Views)
Hi Didi,
why don't you call your local NI support?
(2,128 Views)
http://www.ni.com/pdf/manuals/374737k.html#installation has general info. Then you need the USRP https://www.ni.com/en-us/support/downloads/drivers/download.ni-usrp.html#311694
ALE Consultants
(2,089 Views)
I have installed LABVIEW 2017 FPGA module and Xilinx compilation tool 14.7, but when I connect my USRP 2944R through JTAG cable I  cannot find the option called "New device and target". So how to know whether the installation of the above two modules mentioned is installed properly or not?
Have I missed something?
(1,965 Views)
It sounds like maybe you missed the USRP driver (that I see on reflection Terry already posted).
The Getting Started guide also looks fairly promising (although it passes the responsibility for "required environment tools" to the "manual", which I can't find...)
There's more guidance here: NI-USRP 19.5 Readme
GCentral
(1,949 Views)
