Showing results forĀ
Search instead forĀ
Did you mean:Ā
To get a picture from an image structure
I want to do a SubVI that displays an image in a picture control.
The input is:
an image structure (as a cluster)
The output is:
a picture control (with the image to display)
I'm using the ImageToArray.vi, and I can display a flatten or an unflatten
pixmap. The problem is that I need the palette of the Image, and I don“t
know how to look for it.
Is it possible to get the palette from a image structure?
Miguel.
(3,638 Views)
Miguel wrote in article
<7qggv4$5mq$1@talia.mad.ttd.net>...
> The input is:
What "image structure" do you have? What is the format from which you
extracted this "image structure"? Maybe it's a file, then what format is it
in?
> The output is:
unflatten
Depends from where you got your "image structure".
Rolf Kalbermatter  My Blog
(3,638 Views)
It is, for example, the output named "Image Out" in the function "Imaq Read
File".
I want to get the palette without using this function, only through this image
structure.
Miguel.
> > The input is:
> in?
> > The output is:
> unflatten
(3,635 Views)
