01-13-2021 09:21 AM - edited 01-13-2021 09:23 AM
I am using labVIEW 2019 in Win10. The tip strips option is checked as follows.
But it does not work when I move the cursor over either a control palette object or a front panel object:
What is causing the problem?
01-13-2021 09:44 AM
They only show when the VI is running (or in CTRL+M mode).
In edit mode, they show in the help (CTRL+H).
LabVIEW Programming ((make LV more popular, read this)
01-13-2021 09:50 AM
Thanks! The tip strips are pretty slow to show up.
01-13-2021 10:18 AM
About 1 sec., counting from when the mouse freezes. So no tip strip if you keep moving...
