Timing issue with parallel timed loops
- while running only the acquisition loop: 10-15 %
- while running both loops in parallel: 18-32 %
in both case, all cores seem to be active
Message 11 of 15
(473 Views)
The reason for the slow down is a race condition on the image buffer.
See attached example for correct handling of the image buffer.
Norbert
Norbert
Expert: Geometry
Message 12 of 15
(467 Views)
I cannot opn the example since I have LabVIEW 2009!
Message 13 of 15
(464 Views)
I converted the VI to version 2009.
Cédric | NI Belgium
Message 14 of 15
(418 Views)
Hello Cedric,
Thanks for the effort. First of all, for this particular application I cannot capture a sequence of images just one after another since I need to analyze each frame and output some analog signals based on each image. This means that I still have to capture images within the producer loop. However I tried the example proposed by Norbert and it is obviously NOT the solution because as you know the "IMAQ copy" is computationally expensive and it slows down the iteration time of the producer loop by 8 ms, whilst I am hoping for 1 ms!!!
Message 15 of 15
(409 Views)
