Time value not appearing in colum
please see attached file..
time value only save once when its save first value in xls.
next time row of time colum shows 00:00:00.
how can i solve this problem?
Message 1 of 8
(4,412 Views)
Hi Asif,
By getting rid of ExpressVIs, where you only have limited control over their behaviour…
Why don't you create simple spreadsheet files (aka delimited text files aka CSV files)? With full control of their content and formatting?
Why are there two wait functions in your loop - with different wait times?
Why is there a local variable creating a race condition?
Message 2 of 8
(4,381 Views)
Kindly share the code which is compatible with previous versions like 13, 14 and 15.
Message 3 of 8
(4,368 Views)
Here it is, after a little bit of Code Cleanup (the Broom tool) and a small amount of Structure/Wire movement to make it a little more compact (I renamed it to "protect the innocent").  Note that I agree with GerdW's observations ...
Message 4 of 8
(4,355 Views)
Accepted by topic author JÞB
Thanks to all for your replay,
Bob, it also not showing time value in time column.
after modification my previous code now its working,
check.
Message 5 of 8
(4,331 Views)
depending on the idiosyncratic effect that the Boolean Local will be read before the terminal is written is a poor choice.  You know how to use a shift register, use one there.
"Should be" isn't "Is" -Jay
Message 6 of 8
(4,309 Views)
can you modify my code?
i am unable to understand..
Message 7 of 8
(4,292 Views)
If you're unable to understand such basic hints, I would seriously recommend doing a step back in your learning curve. Or is it only the language barrier? If the former, you could retake the online Core 1-2 learning material. If the latter, some English course could speed up your LabVIEW learning and forum usage efficiency...
Ps: and instead of asking others to modify your VI, you could explain what was not clear in the above suggestion for you. If yourself figure out how to modify your own VI, the learning factor is much higher, believe me!
Message 8 of 8
(4,285 Views)
