09-26-2011 03:07 AM
I tested the VI on a win 7 (32 bit) with LV 2010 SP1.
The VI works perfectly fine. Except of course when the path of destination file is invalid (in which case, it throws an error)
I could not reproduce a hang. Could you try it again. And see which node is causing a hang (or if it hangs right at the start of the VI run)?
09-26-2011 03:39 AM
Actually it runs now but giving me ####### on Excel. and it hangs when i tried to stop the VI.
09-26-2011 03:52 AM
Ah, that's expected. You just need to resize your cell long enough to see the date/time.
Doesn't the VI run completely and end by itself?
09-26-2011 04:18 AM
OK now i found that if i run it continuasly then it hangs but run once is fine. i tried to resize the cell after
running the program and i go "26-15-yy hh:15:02 AM" this. but still not showing the proper format i mean "2011-09-26 11:15:02"?
09-26-2011 04:46 AM
I think the hang must have something to do with your RAM, because I do not see this program being very memory intensive.
About the format, you can just change it in the constant in the block diagram.
Replace the string constant contents with this:
yyyy-mm-dd hh:mm:ss AM/PM
Hope I helped!
