04-07-2011 06:06 AM
Hi, I am trying to compare two timestamps and then going to create a case structure, as far as simple comparison goes it seems ok and easy but actually I want to compare every day or in other words I need the VI to start the particular task every day while running at the given time which means the time will remain fix but the the value in timestamp contstant/control should change automatically to next day.
For example if I put 7-04-2011 1pm .. it just not compare for 7th April but i need it to compare everyday like 8,9,10...april as far as vi is running and every day the task should execute at 1 p.m. I hope the issue is clear and i'll get some useful suggestions.
Naqqash
04-07-2011 06:07 AM - edited 04-07-2011 06:08 AM
Post your vi what you have did so far...
04-07-2011 06:31 AM
Thanks for reply. Here it is.
04-07-2011 06:51 AM
04-07-2011 07:12 AM
Danke Schön. So stupid of me never thought to unbundle the time cluster anyways thanks alot. Only the top part of the program is suffiecient for comparison no need to use format string and then concetenate (might be useful for others in future).
04-11-2011 03:22 PM - edited 04-11-2011 03:23 PM
This little baby is actually in my image gallery somewhere... the subject "time to time of day" comes up quite frequently.
