09-13-2011 06:14 AM - edited 09-13-2011 06:21 AM
When I say hardware, it is your CompactDAQ hardware. So your C-modules are sitting in a chassis. The chassis can only handle one DAQ Ass. at a time for reading values.
From what I can see in the DAQ Ass. it is the same chassis you are runing both DAQ Ass. on. But it can be that LabVIEW is play a trick on me.
Can you confirm what the Physical channels for your inputs are?
09-13-2011 07:08 AM
@ alok.p
only i can see is that if a daq ass is select it reduce the time speed because it needs time to get his values right
@dkfire
your right both c-modules are sitting in the same chassis
but how can i get the different values in one daq ass
if you see i am not an expert in labview
09-13-2011 07:29 AM - edited 09-13-2011 07:30 AM
ok
now i check how i can use one daq but with the time it is the same
is this the max speed for this application
09-13-2011 08:23 AM
I don't understand your question.
Why are you using the Elapsed time function ?
09-13-2011 09:03 AM
the elapsed time is to store my values and change the timedistance between the single values
if i store the values i get 10 values with the correct time distance after that the time make a jump up to 2s and store again 10 values with correct time distance.
this happen also in my graph
09-13-2011 09:56 AM
The problem is the way you have setup your system.
You have asked the DAQ Ass. to get 10 values from the DAQ, sampling at 100 Hz. That will force the DAQ Ass to wait for 100 ms as the sample get ready.
So you loop will run every 100 ms.
You have also asked the Elapsed Time Express vi when 1 sec has passed. And only when that is true you log the current data from the DAQ. You will then only log the 10 current data point, NOT all data points between two logs.
But your graph should update all the time.
Could you run your vi and save the data is collects.
09-14-2011 01:47 AM
Hi
Thank you for your explanation
the graph don´t run fluently it has also the jumps
how can i change my setup ok i can delete the elapsed time but that is only for store my datapoints
in the attachment i only have store one pressure and one temp
