Time column in a file
Hi all,
what is the best way to implement a column for time in a file. And I do not mean a timestamp but a column that shows the time elapsed. So if it measures 100 samples per second I would like it to show 100 rows of samples per second.
I need my file to be easy to read for data analysis.
That is:
1st column: one column for time in seconds
2nd: samples per second
Here is my VI.
Kind regards,
Emilie.
Message 1 of 8
(1,336 Views)
Hi Emilie,
you forgot to attach your VI.
That is:
Best would be an example file to show what you want!
I would just add one column in front of your measurement data holding the elapsed time value…
Message 2 of 8
(1,317 Views)
@erabrannan wrote:
That is:
can we assume that "samples per second" is constant? So why do you need a second column for boring data. More typical would be  time in the first column and  the sample value in the second column.
So you have two columns of data. Can you define "easy to read"? If it should be read by a human later, I would recommend delimited text with tabs separating columns and linefeeds separating rows. If it should be read by another program, consider binary (lossless and fast).
How many rows do you expect to have in the end? Do you want to keep everything in memory and write to file at the end or do you want to stream to file while data is measured?
Message 3 of 8
(1,302 Views)
Here it is!
Something like this:
And as you can see if I chose to have 10 samples per second, for samples it will show 10 rows of data for each second along with its corresponding time
Could you show me how to code that?
Message 4 of 8
(1,249 Views)
yes sorry I meant there should be 100 samples per second, for instance, but the second column would just be the sample value (data). Sorry for the confusion.
Sure, I tried binary. I was told to go for either a text extension or TDMS extension.
I tried to implement a timestamp as described in: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAUbSAO&l=en-GB
However, this is not practical for data analysis. I don't want the exact time (day/month/year) and the second column is in a strange formate (why 0.001?) it doesn't include the time elapsed in seconds as I would need.
Message 5 of 8
(1,246 Views)
Hi erabrannan,
A simple approach would use something like this:
This will only work for low sample rates! It will give errors very quickly when you use the samplerate of 1000S/s as is set as default in your VI…
Message 6 of 8
(1,241 Views)
So I tried to change it like this.
I changed the sample rate to 10.
This is the file I got:
I don’t understand why there are more than a 1000 rows of data when I left it on for like 2 seconds. Shouldn’t it be just 20 rows of data? In any case the first column is still not showing me the time? Maybe I coded it wrong?
Message 7 of 8
(1,231 Views)
it will be read by either python or excel.
But considering it is a couple GB of data, and the TDMS can only be opened by excel, and excel could not open a file that large.
I am not sure to figure how many rows it should have. How do you determine that?
And write to file at the end.
Message 8 of 8
(1,219 Views)
