Three excel graphs showing up on one sheet
Hi again,
I'm not sure why, but when I create three separate excel graphs, they all show up layered on top of each other on the same sheet. Three sheets are being generated, but then the next two are blank. Here's a snippet of what I'm doing and the excel output with some sample data. The whole VI isn't necessary, since the rest of it relies on a MAX task.
Thanks for the help!
And inside the Scatter Plot subVI...
(2,542 Views)
Accepted by topic author try_guy90
Hi Guy,
Take a look at this VI, this might be what you need to change pages.  Let me know if this helps.
(2,539 Views)
Yep, that worked great! Thank you!
(2,536 Views)
